T56 gets stuck in 4th gear
Old Dec 23, 2014 | 08:04 PM
Lswon_nino's Avatar
Default T56 gets stuck in 4th gear
My t56 gets stuck in 4th and when I get it into neutral it won't go into any gear other than 4th. this has happened twice while driving normally
Old Dec 31, 2014 | 08:49 AM
Jeremy@RPMTransmissions's Avatar
When you get it into neutral will the shifter not move from side to side at all?
Old Jan 1, 2015 | 11:21 PM
Rob WS6's Avatar
Sounds like the synchro keys to me... or a bent 3-4 fork, but Id put money on the keys.
Old Jan 3, 2015 | 02:04 PM
k_garretson23's Avatar
what year is the car? pre 02 (maybe 01) had an aluminum 3-4 shift fork. It is very easy to bend when shifting hard. Thats what I did in my 01 z06 and I had the same issue youre describing. Best fix is to get the steel shift fork and never have the problem again.
Old Oct 1, 2018 | 10:27 PM
Thejoker98z28's Avatar
Default How can i talk to tick
Originally Posted by k_garretson23
what year is the car? Pre 02 (maybe 01) had an aluminum 3-4 shift fork. It is very easy to bend when shifting hard. Thats what i did in my 01 z06 and i had the same issue youre describing. Best fix is to get the steel shift fork and never have the problem again.
