Identifying used ls t56
I just got around to cleaning the grime all off of it and found some things of concern.
Theres red rtv at all of the joints, except black rtv between the main case and midplate.
Theres no TREMEC markings on the case, just borg warner.
Theres no green ID tag on the tail housing.
It looks like theres some junk yard yellow maint markings still on the case.
To me it looks like the previous owner may have blown his stock tranny, and bought a junkyard lt1 t56 and changed the mid plate/input shaft and bellhousing.
My main concern is figuring out what year this is from. Is there any way to tell if its the weaker, 93 model t56?
Is this something I should bring up to the seller of the transmission? I feel a little mislead and unsure if I want to run this trans with out tearing it down now.
I'm pretty certain its not the weaker 93 model since it has cags.
Is there much difference internally between a stock ls/lt1 trans other then the input shaft?
The answer is contingent upon "what was changed when it was apart each of the multiple prior times?"
And what year it was serviced.
Red RTV means at least once before serviced. Probably in addition to the input swap.
I read your post for content before spewing out the following.
I called my dealership and ran it as R2208246, W2208246 and X2208246 and they were all autos or V6 cars. So Im probably reading one of the numbers wrong. The 4 is kinda hard to make out.
Unfortunately the VIN is the only way to figure out what it was originally out of.
According to this the 2w at the beginning would mean my transmission is out of a 98 pontiac. Does that seem correct?
That first "2" looks like a "Z" to me.
ZW2208Z46
Can you take another picture of just the VIN area?
If I have any issues I'll have a buddy go through it like he did my lt1 t56.
