Which T56 do I need?
Are all the T56's the same? Is there a difference between the input shaft of a LS1 versus the T56 version I have?
Thanks!
Just for curiosity, since it is using a clutch fork, do you happen to know what type of throwout bearing is used? The set-up I have now has a T56 with an adapter plate the bolts to a Lakewood bellhousing behind a SBC. The adapter plate has a hub on it for the old style throwout bearing.
http://lakewoodindustries.com/ls1-to...mech-fork.html
As mentioned, I do not see any type of hub where the throwout bearing would ride.
Thanks for your help!
Quicktime must make a mechanical adapter but why not just go with the one made as a drop in for fbodys and gto's and retain the stock hydraulic setup
I might have to do some digging and see how much to convert it all back.
Thanks!
