wrench size needed for hyd. fitting
Old Jan 20, 2015 | 04:01 PM
hutchjc1's Avatar
Default wrench size needed for hyd. fitting
Does anyone know the wrench size needed to tighten the fluid line that goes into clutch from the M/C ( not the bleeder, the inlet that is just below the bleeder ) It's an 04 GTO trans, I believe we loosened it while changing to the tick set up. I would like to try to get a wrench on it to verify / tighten it up even if we have to make the tool, I just need to know what size the fitting is, any help would be appreciated ! I really hate to have to pull the trans to tighten that 1 fitting ! The car is a 53 Belair with the LS1 and trans out of an 04 GTO so it is a little roomier than under the GTO
Thanks,
Jim
Old Jan 20, 2015 | 06:19 PM
Project GatTagO's Avatar
Thanks,
Jim
Jim,
The line from the MC going into the slave is an o-ring style that is retained by a pin. Or are you talking about the fitting that goes in that fitting:
http://www.rockauto.com/catalog/more...049&cc=1423044
How do you even get in there when it is assembled?
Andrew
Old Jan 21, 2015 | 08:58 AM
hutchjc1's Avatar
yes it is the fitting that goes into that fitting, the one I need the size for is on the line that threads into to the fitting that you show, and yes it will be a bear to get to. I hope I can make a wrench to do it but need the fitting size, I know the bleeder is 11 mm.......
thanks for the help.
jim
Old Jan 21, 2015 | 03:55 PM
hutchjc1's Avatar
Got it 10 mm !
