Tr6060 syncro keys adaptable to T56?
From pictures, the tr key teeth spacing that ride on the inner synchro collar, appear different between the 1/2, 3/4 & 5/6, rev synchros in both count & size. The later pair appear to have course teeth that may correspond to the t56 tooth count/size?
Any of you mad scientist tinkerer types (85MikeTPI) considered this or pulled it off?
Yes, the synchronization teeth that mesh the slider to the gear are a mis-match in count, profile, ring diameter.
In short, you'd have more custom pieces than it would be worth.
There are multiple pieces to the shift linkage that relate to how shifts feel outside of the synchronizer keys. Implementation of the TR6060-utlilized parts began in the CTS-V.
The t56 design just always seemed like a clunky, unrefined approach.
It seems to me shift quality would be more dependent on the front offset lever/shift detent assembly interaction, and to a lesser extent the offset lever detent ball/guide plate pockets.
Thanks for your input
If you're meaning rotational indexing, the synchro hub/collar cogs would be responsible for that?
Seems they both serve as just detent pressure, just two different approaches
Fatigue, whether spring tension or key material.
Aggressive shifting.
Worn/broken shift pads.
Excessive synchro hub/collar clearance.
Clutch drag (not fully disengaging-failing hydrs.).
All the above?
