T56 quick connect problems
Old Jun 13, 2015 | 03:28 PM
jjgjosh's Avatar
Default T56 quick connect problems
I have a 99 camaro ss drives and shifts fine under normal acceleration but when banging gears the quick connect pops out . The fitting is a little chewed up. Will this be a better replacement for the hydraulic line with these or do you recommend something else. also should I replace the slave cylinder at the same time
http://www.speedwaymotors.com/McLeod-139204-23-Camaro-F-Body-Trans-T56-Hydraulic-Clutch-Line-22-Inch,9086.html
And this http://www.speedwaymotors.com/LS1-and-LT1-T56-Release-Bearing-to-AN3-Line-Fitting,25017.html
Old Jun 15, 2015 | 07:47 AM
jjgjosh's Avatar
Has anyone experienced this problem also has anyone used the McLeod hydraulic line for a replacement
Old Jun 16, 2015 | 09:03 AM
Project GatTagO's Avatar
The hose you referenced has a AN-4 fitting at the MC end, while the adapter you listed is a AN-3 male. Won't work together. The McLeod line is designed for swapped cars that use the F-body T56 with a Wilwood MC.
Andrew
Old Jun 16, 2015 | 06:38 PM
jjgjosh's Avatar
Thanks for your help would this this one fit for stock replacement
http://m.summitracing.com/parts/mcl-139212
Old Jun 16, 2015 | 07:32 PM
That looks like it would work, assuming the male fitting is the same size as the female fitting on the hose.
Andrew
