LS1 clutch bleeding problems
Also if the bubbles seems to be gone and I increase the vacuum preasure a little more, a lot of more bubbles comes out. This will take several hours I think, unless something is wrong so air get's in somehone?
When I press the clutch pedal it feels ok I guess, it comes up from the floor so not that it's stays down or so, which I guess it might do if there are to much air in the system, but I'm not sure I would dare to drive it. I still have to adjust the pedal and since it's now at it's shortest position I guess it might be difficult to bleed the system because of that?
Should I try and adjust it and run the vehicle and continue with the bleeding after or should it work even when the pedal is as it is now?
I also followed the instructions for getting that last bit of air out and my clutch pedal has been perfect for 2,000 miles.
Others may have had success with the mityvac - I didn't.
