M6 conversion questions
Old Oct 22, 2015 | 06:22 PM
b4ctrooper's Avatar
Default M6 conversion questions
Found a 94 LT1 Z28 parts car complete. It has a 6spd, and I need one for an LSX conversion. Can that transmission fit behind the LSX engine? I know the flywheel will be different, but aside from the parts I'd remove from the 94, what would I need to make it work? Thanks.
Old Oct 22, 2015 | 07:34 PM
txazformula's Avatar
essentially have to change front plate of lt t56 tranny to lsx and input shaft length is different; gm hi tech mag did a conversion article back in the day, march of '12 issue, search super chevy archives for 411
Old Oct 23, 2015 | 06:51 AM
redbird555's Avatar
You would need an ls bell housing, mid plate and input shaft. Swap takes about an hr the parts would be roughly 300ish plus a bellhousing
Old Oct 23, 2015 | 07:11 AM
b4ctrooper's Avatar
Ok, thanks!
