Removing mangled pilot bearing suggestions needed
First I got a loaner puller from Advanced Auto. The finger ends on it were not 90 degrees but kind of tapered; and this was a never used before tool. So it ended up crushing the roller bearings a bit. I returned it.
I then got the "right" puller (OEM brand 27059) at Pep boys, and slide hammer. This one pulled all the rest of the rollers and the cage out, and then one of the arms broke off. I returned it but they didn't charge me, cool. The main bearing body remains.
So I am waiting for another one of the same to use, and am hoping that it will be able to grab the body of the bearing. But if it gives me problems, is there any other method to pulling the bearing? I see a spot of rust on the groove between the bearing and crankshaft and if that goes in farther I am certainly in for some seriously fused metal. :-(
My other last resort is the puller with 4 fingers, not sure where to rent that from in my area.
Any creative and non damaging (to crankshaft) methods of removal suggestions appreciated.
I use a wooden dowel piece I cut from some closet rod piece I had to hammer in new bearing
It is called a "blind hole puller" and I assume it is available elsewhere but my local AZ has it.
I to have driven more than 45 min to get a "tool" for various reasons.
maybe spray some PB or liquid wrench around old pilot bearing and let it sit. I have never had to but you mentioned rust so that may help
