T56 Problem Need Help!!
Does it grind as soon as you start letting the clutch out?
Does it fall into 1st and reverse (from neutral) nice and smoothly with the car running?
Tranny/bellhousing doesn't have any noise coming from it at idle?
I guess it would be possible for something to be damaged from the rear end breaking but right now I'm not convinced.
I guess you can also have someone else try to move the car while you lay down listening to locate the noise to the transmission or rear.
