Grinding when clutch is being released
Old Jun 20, 2016 | 12:24 AM
LStrev530's Avatar
Default Grinding when clutch is being released
I recently picked up a 2002 Camaro Z28 six-speed with 109xxx miles. Only problem is that after about 15 mins of driving when I let the clutch out it grinds, only when I take off and sometimes when I shift to second. Then I will lose pressure in the pedal. I have bled the system (vacuum bled through reservoir) and the fluid turns black after I test it out. I have changed the transmission fluid what next steps should I take???????
Old Jun 24, 2016 | 01:42 PM
Centerforce's Avatar
These issues indicate a possible failing slave/throwout. Is it difficult to put the car into gear with the clutch in?
Old Jun 24, 2016 | 03:10 PM
SNLPerformance's Avatar
When you are experiencing theses issues is it during normal, or hard driving?
