is it neccessary to update a 00 slave to a 01 slave?
Just messin with you guys. Last edited by freakynipples69; Jun 21, 2004 at 12:25 PM.
$90 part that takes 5 minutes to replace if you're already changing the clutch.
if you want an 02 master with 11k miles, i'll sell you the one i've got that i did not use
I have the 01 slave (Car is an 01 model) and I am here to tell you that you are wasting your dad's money... Your clutch is sticking to the floor when you rev it either because of air in your system or burnt fluid. All you really need is fresh fluid to cure your problem. If you were to upgrade your master and slave to the 01 model, The problem probably will go away for a while (Because you BLED the system) but give it a summer or two of driving in the heat and it will come back... Just because you have done the 'drill mod' or upgraded to some 01 parts does NOT mean that your pedal won't stick to the floor when the fluid gets hot and burnt...
And later on down the road, after you change out all these parts and the pedal sticks to the floor again, What do you replace then? Save some money for other mods and just bled your system real good...
So have daddy swap your slave cylinder.
I do have one question though: If the slave on my car has all of these 'problems' moving the fluid and this causes the pedal to stick to the floor, Why did it NOT act stupid from day one? Why did the thing wait 20k miles to start messing up? Why did it only hang up when the car was hot?
And best of all: Why did the pedal problem go away when the fluid was flushed and system was bled?
I just sort of figured that if my slave was screwed, my problem should have remained no matter what I did to the fluid.
I can't really say for sure if the 01 slave is 'better' than others or not because I am NOT a GM engineer, but I know for sure that stuff like clutch fluid can and does get contaminated over time. High heat will speed this up.
