Reverse lockout - how to connect in swap
in high speed, when I will put 5th, sometimes almost enter reverse...
how should I do to work? should put 12v and a switch in reverse lockout?
thanks for the help
You can also buy a HURST shift **** with a button and wire/activate release that way
on GM car it is controlled by PCM to release under 3 MPH
the Reverser Lockout conector, have 2 wires, 12v and ground?
when 12V and ground it release to shift into reverse?
Actually I dont have nothing there... is a little difficult to put reverse, but in this case, it shouldnt do this when put 5th, right?
What shifter do you use? Something like an MGW will pretty much prevent missed gears by itself.
People do run without any reverse lock out and have no problems finding 5th be it up or down shift without buzzing reverse.
A shift ball with a button is another option. Typically those buttons are wired to line lock (roll control) but could also be wired to reverse lock out instead
And no idea how people can get away with those alloy sticks....mine broke in a number of weeks.
With the extra spring you basically have to give a full body lean with your weight behind it to get far enough over to find reverse
Although a friends Monaro/GTO with a different shifter, he cannot select reverse unless the solenoid is powered.
I guess some may be stronger than others.
Either way, he has an aftermarket ecu, it should be easy to use an output that will trigger based on roadspeed or some other parameter he can use,
Andrew
