Slave Cylinder Question
Old Jan 13, 2017 | 07:25 PM
Flamed350's Avatar
Default Slave Cylinder Question
In doing the LS swap into my camaro we mounted the master cylinder. The slave is attached to the master. We pushed the pedal down a couple times to make sure outlr angle was good and nothing was in a bind. In doing that we heard clicking coming from the slave and i noticed a little fluid coming out of slave. I also noticed that the top ring with grooves had popped out so i pushed it back on and the leak stopped. The slave moves up and down no issue. Just wondering if we hurt the slave by doing this and if i should buy a new one!? Thanks for the help.
