Able to access reverse gate at any speed
You could also try unplugging the harness from the transmission, then try to shift into reverse. If it won't go into reverse easily, the solenoid is good and the problem is in the wiring. If it still goes into reverse while unplugged, the solenoid is broken / stuck.
Andrew
