ls7 flywheel question?
Old Feb 7, 2017 | 08:45 PM
taman86's Avatar
Default ls7 flywheel question?
ive been scouring the forum and google and cant find a specific answer to my specific question. I have this idea to use ls7 bottom end in my future build project and really wanting to build a weekend street warrior and road course engine i.e. titanium. I know the ls7 flywheel and clutch is heavier then the ls6. I also know that all ls engines use the 6 bolt flywheel pattern. my question then is the ls7 flywheel specific to the ls7 crank such as offset or something or can the ls6 clutch and flywheel be used on the ls7 crank without causing to be out of balance or what not? my goal is to have as much of a lightweight rotating assembly as possible. thank you
Old Feb 12, 2017 | 06:55 PM
ITSWILL's Avatar
Both are internally balanced engines.
