Another clutch question??
Old Jun 26, 2004 | 04:02 PM
Absolut's Avatar
Default Another clutch question??
Hey guys, sorry for the question, but I couldn't really find my answer through searching... Here it goes:
I'm replacing my clutch on my 2000 WS-6 after 26k miles. I'm buying a Spec stage 3 or 3i, but I don't know too much about clutches. Which parts should I replace? Everything? Flywheel? Pressure Plate? Should I just have it resurfaced?
Any information you could provide would be great. Thank you!!!!
Old Jun 26, 2004 | 05:30 PM
pacmantravis's Avatar
Im not an expert, but this is what I have read.
You should get a new flywheel instead of resurfacing it. Supposedly our stock flywheels warp easily when resurfaced.
I have a clutch swap in the works and this is what I have planned.
- Updated GM Hydraulics
- New Pilot Bearing
- Spec Stage 3
- Spec Billet Steel Flywheel
Old Jun 30, 2004 | 09:41 AM
Absolut's Avatar
Thanks for the reply. I only have 26k on the car right now and my current GM hydraulics (slave cylinder) isn't leaking so I think I'll just get the clutch kit with flywheel and pilot bearing. Good idea?
Anything else I should consider replacing at this time (Clutch related)?
Thanks.
Old Jun 30, 2004 | 10:59 AM
Tranzor's Avatar
You should upgrade to the '01-'02 hydraulics... you'll thank yourself later.
Old Jun 30, 2004 | 11:29 AM
Absolut's Avatar
Okay... Twist my arm.
Thanks!
