1998 ws6 Trans Am 6-speed
Old May 29, 2017 | 11:34 AM
taws6ali's Avatar
Default 1998 ws6 Trans Am 6-speed
I Installed new tick master cylinder, and new GM throw out bearing. I currently have no fluid in my resrvoire. But even tho the rod on the tick cylinder was longer then my oem my pedal is bottomed out. Is this normal ? Or am being too worried? Will get some brake fluid and try to pump and bleed to see if that works all help needed thanks
Old Jun 4, 2017 | 01:06 AM
eb110americana's Avatar
Yeah, that's normal for no fluid. Even for an air bubble in the line, it can happen.
