Reverse not working
Old Jun 8, 2017 | 04:11 PM
smws6ta's Avatar
Default Reverse not working
Does anyone know if the 2nd gear skip shift solenoid works also for the reverse lock out?
Gears 1-6 are fine but I can't shift into reverse.
Old Jun 8, 2017 | 04:36 PM
LLLosingit's Avatar
I have a tr6060 not T56 but I imagine they are the similar, They each are controlled by separate solenoids.
Old Jun 8, 2017 | 05:54 PM
BALLSS's Avatar
2 separate solenoids for the T56. Either wiring to the reverse lock out or the solenoid is bad
Old Jun 9, 2017 | 10:45 AM
smws6ta's Avatar
Thanks.
I'll be ordering one on payday.
Old Jun 9, 2017 | 02:44 PM
BALLSS's Avatar
might want to meter the connector first. KOEO you should see +12v
