Stuck shifter
Old Aug 14, 2017 | 11:14 PM
Jaimejavier's Avatar
Default Stuck shifter
so I was heading home a few weeks ago and my master and slave cylinder had went out(well I assumed they did due to my clutch not working and feeling all spongy) but at the same time they went out my shifter had got stuck in gear and it wouldn't let me shift into neutral and if I did the gears would grind but it was difficult to find any gear. So I replaced both the slave and master cylinder and bleed the system. And now my clutch feels better than ever but my shifter still stuck I got it into neutral but it feels like it's grinding every time I tried to put it into any gear. What could that be
Old Aug 15, 2017 | 08:44 PM
nm2769's Avatar
Can you shift gears with the engine not running? If not you may have sheared a syncro key.
Old Aug 24, 2017 | 07:41 PM
Yeah I can shift it when the engines off
Old Aug 25, 2017 | 08:33 AM
Guitar's Avatar
Same thing happened to me a while back before I built mine, required a rebuild. I think synchros were trashed or shift fork was bent...either way.
