Tracking a tick - slave noise?
Are you sure it isn't an exhaust leak? A leaking header flange will tick like that.
Andrew
So my understanding (which is little) is that the throwout bearing is what makes contact with the clutch fingers. If I am not pushing the clutch in, this shouldn't be making contact, correct? I'm getting this tick at all times, in gear or out, moving or not, clutch in and out, idle or revving.
