CTS-V Drill mod? fluid?
This forum is always so helpful I wanted to thank you in advance...
My questions are simple:
Is the CTS-V hampered by the same flow restrictors as the vette and F-body? If so, where are the restrictors and what should I do.
Second, I'd love to do a first change on the T56 fluid. I'd like to run the first stuff for a short time (I'm near 6k miles) and I plan to run the second fluid longer. What fluid should I use?
Now, an issue. I do suffer from a bit of a problem. I occasionally find it hard to shift into first. I will sometimes throw the shifter into second then back to first to ease engagement (of lever, not clutch pedal). What could cause this? Is this normal functioning of the tranny?
Thank you in advance,
WL
