What year trans do I have guys? Any help would be greatly appreciated
its the last 3 #'s that don't match up to what info I have
Trans/source 1 s t 2nd 3rd 4th 5th 6th Max torque
1993 LT1 F-body T56
w/2.73's
3.36 2.07 1.35 1.00 .80 .62 350 lb-ft
1994-97 LT1 F-body
T56
2.66 1.78 1.30 1.00 .74 .50 450 lb-ft
LT1 F-body T56
w/3.23's (G92)
2.97 2.07 1.43 1.00 .80 .62 400 lb-ft
Trans/source G M p art number Tremec part number
1993 LT1 F-body T56
w/2.73's
10236020 13-86-000-006 or
1386-000-006
1994-97 LT1 F-body
T56
12550647 13-86-000-016 or
1386-000-016
LT1 F-body T56
w/3.23's (G92)
10236021 13-86-000-011 or
1386-000-011
1993 LT1 F-body T56
w/2.73's
1994-97 LT1 F-body
T56
LT1 F-body T56
w/3.23's (G92)
1993 LT1 F-body T56
w/2.73's
1386-000-006
1994-97 LT1 F-body
T56
1386-000-016
LT1 F-body T56
w/3.23's (G92)
1386-000-011
Tremec bought Borg Warner T56 and GM had their own part #
The one you want is from a 94-97 with the 2.66 1st gear as it has the highest TQ rating
You could put it in 1st and rotate the input shaft 1 turn and count how many turns the rear spline turns. The 3 different ones available from 93-97 had different 1st gear ratio
93 has 3.36 1st so the rear spline should turn 3 1/3 times. 400 ft lb rated
94-97 has 2.66 1st gear so rear spline would turn slightly more than 2 1/2 times. 450 ft lb rated
LT1 F Body with 3:23 rear gear had a 2.97 1st gear so the rear spline would turn "almost" 3 revolutions. 400 ft lb rated
