Grinding Under Load
Old Jun 17, 2018 | 11:11 AM
bdrinkman's Avatar
Default Grinding Under Load
I have a 2002 LS1 W/T56. I recently tried to stop an oil leak that was on the pressure sending unit off of the oil filter housing. After I thought I tightened everything correctly and test drove it I downshifted from 4th to 3rd and it starting grinding severely. I coasted to a stop and tried to start off again in 1st with no issues, shifted into 2nd and put a little power to it and something disengages to loose all power and terrible grinding happens. Under any sort of load in all gears this now happens, even with downshifting. I still have the bad oil leak too. Is this simply my clutch slipping from the oil leak or something far worse?
