02 WS6 trans question
Old Sep 6, 2018 | 09:01 PM
twins09's Avatar
Default 02 WS6 trans question
I started up in neutral....put it in reverse and it stalled out......I went to start in neutral but it would not start but it turned over....I moved the shifter but it only get to into 1,2,3 or 4th. This is when the car is off key in the ignition....it will start in any of those gears. It drives fine and shifts through all the gears. Could it the neutral safety switch.
