Is there an exploded diagram of the T56?
I'm in the UK and have a leak from the transmission in my '99 Camaro 6 speed. It looks to be from a gasket/seal around the top plate either under/around the shifter. Haven't pulled it apart yet. Just had a quick look when it was up on a highlift.
Anyone have a good diagram showing how and where this bit might and what the part number is.
I'm not sure if someone has messed about with the shifter in the past, as the interior trim is partly missing and it has a different gearknob fitted.
Thanks.
But really if you think it is leaking there, check the breather is not blocked and that there isnt too much fluid in the box.
Then look at the shifter and check the base is sealed to the box and shifter boots etc are all in good order if present. Although I've had shifters in the past that simply leaked up through the mech itself
There are no gaskets around the shifter though, only sealer.
