rebuild tranny
Old Jul 8, 2004 | 08:39 PM
muscratmauler's Avatar
Default rebuild tranny
Not shifting smoothly into next gear (slight hesitation), better however since dot 5 fluid, but still there. Got stuck in 4th twice. I think it's time for a rebuild. I heard D&D and some other place. Any ideas on what should be replaced 425 rwhp. I don't know much about trannies, but I figured: syncros, cones ..........
any help appreciated.
THANX
MAULER
Old Jul 8, 2004 | 10:22 PM
ESP101's Avatar
have a t 56 all done if interested call me at 203 619 4732 has steel shift forks billit keys good syncros polished hubs for smooth shifting usely 1775.00 shipped have 1 in stock 1500.00 plus shipping with your old core
Old Jul 9, 2004 | 04:41 PM
anyone have some info on upgrades?
Old Jul 10, 2004 | 12:15 PM
rons 00z's Avatar
esp how does your tranny compare to d&d's?
heres their stats for referance.
550 lb-ft Torque Capacity
1.125 x 26T GM Input Spline
30T Viper Output Spline
Close Ratio w/ Deep Overdrives(2.66/1.78/1.30/1.00/.74/.50)
Carbon Fibre Blocker Rings
Steel 3-4 Shift Fork
Precision built and blueprinted by D$D technicians
Direct bolt-up to GM Saginaw/Muncie/T10 bell housings
Direct bolt-up to McLeod 8630 series steel bell housings
Accepts stock GM clutches,linkage,T.O.B.,pilot bearing,trans. mount
7T GM Mechanical Speedo Drive or Electronic Speedo Drive
Old Jul 10, 2004 | 12:47 PM
ESP101's Avatar
it dosnt have the viper output shaft but it will handle the torque we sold many and there holding up fine if interested call me at 203 619 4732 thanks
Old Jul 10, 2004 | 03:24 PM
rons 00z's Avatar
what would it cost to have the shaft put in? i want everything to be upgraded short of getting it all cryo treated.
Old Jul 10, 2004 | 06:52 PM
somss02's Avatar
I spoke to D&D also. For your HP you shouldn't worry to much about the output shaft. They told me that and I'm at 502 RWHP. I have upgraded my forks, carbon blocker rings and the gears. That should do it for you. Call them!! They are very helpful and will not try to sell you anything that you don't need!!
Old Jul 10, 2004 | 07:35 PM
ESP101's Avatar
how much hp do u havewe had 570 hp 600ft pounds of torque and the tranny is mint
Old Jul 10, 2004 | 11:22 PM
rons 00z's Avatar
not sure of hp but as of now it's a full bolt on car. tranny should hold untill the new motor. so for the pricing with out core will cost 1775 shipped right?
Old Jul 11, 2004 | 08:03 AM
ESP101's Avatar
No Its 1500.00 With Core Plus Shipping
Old Jul 12, 2004 | 12:21 AM
rons 00z's Avatar
what is the cost with out the core? i cant afford the down time plus i'd like to experiment with my current tranny. i would call but i dont have cash in hand as of yet. i just want to get my research done by the time i make my purchase.
Old Jul 12, 2004 | 10:03 AM
ESP101's Avatar
The Core Charge Is 750.00 Cant Find Good Cores Thats The Problem Let Me Know Thanks
Old Jul 18, 2004 | 07:59 PM
I am trying to get info. on what can and/or should be replaced. I can't use 4th hear. The majarity of these posts are not answering my question. START YOUR OWN THREAD!!!! I need to get my car FIXED!
Mauler
Old Jul 30, 2004 | 01:39 PM
somss02's Avatar
Mauler call D&D Performance and they will tell you what needs to be replaced. They will not try to sell you anything that you don't need. Trust me, I called them and they were GREAT on the phone, I was expecting to spend much more!
Old Aug 17, 2004 | 01:14 PM
anyone have the number?
thanx
Old Aug 17, 2004 | 01:22 PM
JRcamaroZ28's Avatar
www.ddperformance.com
JR
