Tick master cylinder install issues.
Old Oct 22, 2018 | 06:40 PM
Shadyredeyes81's Avatar
Default Tick master cylinder install issues.
So I bought a tick master cylinder for my LT1 and let’s just say that installation is almost impossible in my opinion. I can’t get the dang thing installed at this point. I took it completely apart because I see absolutely no way to get the entire assembly into place as a whole. I’ve been able to get the aluminum mounting block attached to the firewall. But that’s about it. Now I can’t get the actual cylinder to line up with the two studs coming off the aluminum block. It’s close, but with the large wire loom running up the base of the engine compartment I can’t get it to line up. I’ve tried to move the wires up and out of the way but that only seems to make it worse. Without the hydraulic line attached to it the cylinder is hitting the chassis down behind the strut mount tower. What else can be done at this point?
Old Dec 16, 2018 | 06:26 AM
Bengtson95's Avatar
I thought the master install was going to be a 2 hour thing. I spent so long on that too. U really have to have 2 people and unbolt all the stuff in the way. The wires are a PITA but u dont think I moved those, be sure that clutch line isn't close to the headers or ull boil ur fluid and lose pressue
Old Dec 17, 2018 | 02:48 PM
Darth_V8r's Avatar
Moderator
It's a lot easier if you remove the brake booster. You may be dealing with years of firewall flexion. I remember seeing a video showing how much the firewall moves every time you press the brakes and clutch.
Old Dec 18, 2018 | 09:25 PM
01CamaroSSTx's Avatar
I second the brake booster and another set of hands. No fun lying on your back with your feet up in the air keeping a light on things and trying to wrench in that awkward position that's for sure.
