Adding a Clutch Position Switch
Old Oct 29, 2018 | 05:35 PM
Hardcoresoldier's Avatar
Default Adding a Clutch Position Switch
Interested in adding a clutch position switch for data log purposes. Will NOT be connected to the factory ECM - just the data logger. Suggestions on what to get?
Old Oct 30, 2018 | 08:45 AM
weedburner's Avatar
Why not add something like a shock position sensor to monitor the sweep of the pedal rather than a simple on/off switch?
Grant
Old Oct 30, 2018 | 11:13 AM
xny1989's Avatar
Could you use the "signal" that is used to prevent starter from engaging until clutch pedal is depressed?
Old Oct 30, 2018 | 01:21 PM
weedburner's Avatar
I'm not sure how that type of data could be very useful.
If the OP used a shock travel sensor to monitor clutch pedal travel, that could be useful for mapping out the pedal's "sweet spot" to improve the launch. I use a sensor to record hydraulic throwout bearing pressure to basically do the same thing. After one finds that sweet spot, the trick then becomes to find a way to hit that spot instantly and consistently.
Grant
Old Oct 30, 2018 | 07:47 PM
Grant
that is what I was wanting to do - be able to log actual position rather than just on/off.
Old Nov 2, 2018 | 05:54 PM
stevieturbo's Avatar
It'd be easy to add something either to the pedal, or simply stick a pressure sensor on the hydraulic line. Whilst not strictly speaking position....still directly related to position
