Slave shim question...
Old Dec 1, 2018 | 11:35 PM
wannafbody's Avatar
Default Slave shim question...
I just purchased a Diamond Stage 2 clutch and got a Luk slave cylinder which looks to be the same as the GM part. The Diamond clutch came with a shim but I realize the clutch fits multiple vehicles. Does the 98-2002 Fbody with T56 require the shim?
Old Dec 2, 2018 | 08:17 PM
Crf450r420's Avatar
remove spring and install on trans then measure compressed to bellhousing. then measure from block to clutch fingers. you need a liitle gap between bearing and clutch fingers, but if to large it needs shims. can't remember exactly, so do a search should confirm the gap. probably around .150" to .250", but look it up and measure to be sure
Old Dec 5, 2018 | 10:39 PM
wannafbody's Avatar
I got an answer directly from Jason. He said on the Fbody to use the shim for best pedal feel.
