Junkyard T56
Old Dec 16, 2018 | 01:38 PM
Crane91's Avatar
Default Junkyard T56
I have been looking for a T56 for a while, naturally they are $$$$.
I found this T56 in a pile at the bone yard yesterday. Aside from the other half missing, I saw the front main shaft bearing to be shredded. Curious, would it be worth picking up for $30-40 and having a trans shop rebuild it? I figured it’s there for a reason but I’d like to get some “expert” opinion before I rule it out.
Old Dec 17, 2018 | 12:21 PM
Project GatTagO's Avatar
If you can get it that cheap, and provided the case is not broken, it is worth it.
Andrew
Old Dec 23, 2018 | 10:13 AM
KLowR6's Avatar
Easily worth it, man I wish I found T56s for that much, even 50% complete it’s worth that.
Old Dec 23, 2018 | 12:19 PM
Crane91's Avatar
Not sure if the pics uploaded... I’ll try and reupload them
Old Dec 23, 2018 | 03:19 PM
Crane91's Avatar
Here are the pics. These are all the casting numbers I could find. I know it’s missing about half the stuff it needs to bolt on and drive down the road.
Would it be worth buying the parts the trans needs (assuming what is there is good) and having someone put it together? Vs buying a used trans from Craigslist with 100,000 + miles?
Old Dec 23, 2018 | 03:44 PM
That looks like a Corvette the trans, but I am not 100% sure.
Andrew
Old Dec 24, 2018 | 02:52 PM
stevieturbo's Avatar
With the shift rail extending forward, could well be a vette.
Given the amount missing and corrosion inside, I'd struggle to see any real value in that
Old Dec 26, 2018 | 06:11 PM
jmd's Avatar
jmd
Challenger, but not a promising core.
