Removing bearings..
Old Mar 3, 2019 | 11:05 AM
HappySalesman's Avatar
Default Removing bearings..
Anyone have any good tips on removing the bearings in the t56? Specifically the 2 on the countershaft and the one on the input shaft? The bottom of the race is pressed right against the gear so I can't get my bearing puller underneath it, and it just wants to pull up on the cage. Cutting them off is an idea, but I'd rather avoid that if possible.
Thanks!
