C6 Drivetrain components weight
Old Jun 16, 2019 | 12:07 AM
Mrme4u's Avatar
Default C6 Drivetrain components weight
I am planning to swap a C6 Drivetrain into my Race Car.
And would like to know the components weights
1. Differential unit
2. Manual 6 Speed Transaxle
3. Torque tube
Also curious on.the following dimensions.
1. Centre of the CV on the diff to the front of the transmission.
2. Length of the Torque Tube including the Bellhousing that sits against the engine
Thank you.
Old Jul 21, 2019 | 04:14 PM
gnx7's Avatar
Your best bet would be to ask this on the corvette forum.
I have this manual 7 speed/diff/axles etc if you are interested with CF torque tube/dshaft that can be bolted up to an LS engine with aftermarket clutch/flywheel!
https://www.corvetteforum.com/forums...-actuator.html
