Slave / Master Problem????
I've blead everything, multiple times, did the bushmans Mightyvac thing and all. But my clutch is grabbing right off of the floor. It doesn't even disengage fully. I didn't bleed the slave before I installed the tranny, but fluid is just running out of the bleeder on the slave.
Since I went with a new Slave, It came with a throwout bearing installed, so I didn't run the Spec Throwout. Also I didn't shim anything due to the fact that I have the McLeod hydraulics.
Do y'all think I still have some air somewhere, or should I just adjust the Mcleod master & hope that's the problem?
