T56
Old Apr 18, 2020 | 07:15 PM
khiz's Avatar
Default T56
Hey guys hoping someone can help.
i bleed the clutch and things are good but then a short drive later the trans gets notchy. Shifting through gears it is very rough. Grinds in 5th (not on a downshift from 6th). I’m thinking air in the system but I’ve bled it like 10times.
running a ls1 / t56 in a rx7
wilwood master with oem gm slave and tick remote bleeder. Monster stage 2 clutch
Old Apr 18, 2020 | 10:03 PM
b00stleak's Avatar
I'm no expert but there has go to be air in the system. I have read other threads where people were having trouble with aftermarket masters and bleeding them. Did you bench bleed it first?
