T56 issues
Old May 13, 2020 | 06:34 PM
Angelo Robert's Avatar
Default T56 issues
Hello all -
2002 WS6 with procharged 408 iron block. Having issues with T56 - normal driving it’s fine, under load it has issues going into 3rd from 2nd and when downshifting from 5th. Never used to be that way. Also, today it got stuck in 5th - was able to get it out. Is this common? In need of a rebuild? Better off getting a different trans? Want to say with manual. Any help is appreciated.
Old May 13, 2020 | 09:36 PM
rising_4rm_ashes's Avatar
Originally Posted by Angelo Robert
Hello all -
Before tearing things down I would make sure you don't have air in the line. Did you change the fluid in the master/slave recently? Maybe it just needs to be bled. Just a thought.
And if you decide to upgrade, I had a great experience with Jason from Texas Drivetrain.
Old May 13, 2020 | 10:22 PM
Thanks for the info....no, I have not done that. Changing oil and blower oil this weekend. Last trans service was about 7yrs ago - but I only put about 500 miles on a year so I thought I’d be fine. I’ll check that this weekend too.
Old May 14, 2020 | 09:27 AM
It could be that when the clutch/slave fluid is heating up it's preventing the slave from functioning appropriately.
Old May 14, 2020 | 12:24 PM
chrysler kid's Avatar
Change the transmission fluid. I reccomend it once a year if the car sees a summer of hard use
Bleed the clutch and make sure it's brand new fluid. Brake fluid can break down and absorb moisture and boil at high temperatures. As mentioned make sure the line is wrapped with thermal insulation especially if you have long tube headers
Swap the master cylinder with an adjustable tick or ram setup. They can push more fluid
Old May 14, 2020 | 02:04 PM
I also have a Tick Master. One of the best investments I have made.
