T56 question
Old Jul 31, 2020 | 05:19 PM
98_wssixer's Avatar
Default T56 question
I recently bought a 2002 ws6 and long story short 3rd and 4th synchro is bad and I was curious as to if a t56 out of a lt1 car would go in and also if it would matter if it came out of a non traction control car as mine does have traction control
Old Jul 31, 2020 | 07:15 PM
440_Stroker's Avatar
It is not a bolt in swap.
Old Jul 31, 2020 | 08:09 PM
jmd's Avatar
jmd
Traction control changes nothing in/on the trans. Any 98-02 F-body T56 fits.
The LT1 box would need parts changed and bearing clearances re-set, at a minimum.
Old Aug 1, 2020 | 02:58 PM
Darth_V8r's Avatar
Moderator
You would have an easier time swapping in a magnum F than trying to make a LT1 T56 work. Probably cheaper too after you do all the modifications
