Clutch master cylinder and pedal height
Ok , so I had a Tick MC installed; however it started to leak. I bought a new factory Clutch MC to install/ as I need to drive the car , while I get the Tick MC repaired.. I bench bleed the factory MC..the hose does have the drill mod, I installed the factory MC, but I noticed the clutch pedal sits about 1/2 - 3//4 lower than the brake pedal .. it’s been a while since I’ve done one of these m but I seem to remember with the factory MC installed.. the clutch pedal was the same height as brake pedal... So now the clutch will not engage . I even re bleed the line to make sure the air was out .. tried again ... no luck ... latch won’t engage. Anyone have any Idea or suggestions what could be going on ..
Thanks for the help in advance..
Thanks
Richard
Thanks
Richard
