Speed sensor VSS run-around...
I’ve got a camaro SS tr6060 with a factory 3-wire Hall effect VSS.
I simply need a sinewave Signal to my 411 pcm (like what the f-body t56 2-wire sensor sends).
-is it possible to simply swap sensor out for a 2-wire sensor or is the reluctor wheel different also?
-which sensor will work? Anyone know? Thanks a ton!
VSS location on this tr6060 trans is passenger side near shifter.
i don't want the Dakota Digital module on this build.
post 15 here
Mating a SBC/BBC Trans (T10, Muncie, Richmond, TKO) with an LS motor - LS1TECH - Camaro and Firebird Forum Discussion
