Pilot Bearing Question???
What pilot bearing should I be running. Car is stock motor and rear end. I wanted a stronger clutch, pressure plate, and flywheel after replacing the master/slave cylinders.
I contacted McLeod last night but their phones were off and all I could do was submit an email request. I will call them today and hopefully get through, last time I was on hold for 2 hours.
My Centerforece Dual Friction clutch kit came with three different roller pilot bearings. The instructions were very clear on how to measure to insure that the right one of the three were installed in the back of the crankshaft. Maybe that 43001 bearing isn't the right one?
