How to test MC?
Old Nov 12, 2020 | 10:44 AM
JF74chevelle's Avatar
Default How to test MC?
How do you guys test to see if the MC is in good shape. I’ve seen some forum posts saying you disconnect the line form the master to the slave and then when you push the clutch pedal it should be stiff? I did that and mine is not stiff, it’s soft but the pedal comes back up. It just pushed the fluid from the res out. It’s a tilton 3/4 master cylinder.
