Bellhousing alignment - Is it even helpful?
1. Even if done with 100% accuracy, it completely ignores any misalignment between the bellhousing and transmission. If we are going to worry about the inaccuracies associated with the dowel pins between the block and bellhousing, why would we expect those between the transmission and bellhousing to be any better?
2. Because the T56 bellhousing does not have a circular aperture for the input shaft, doing a bellhousing alignment on a T56 bellhousing requires that a plate be bolted to the bellhousing. The issues here echo those above. And because the plate could be off, a ‘perfect’ alignment with the plate might be more ‘off’ than what you would have with the stock dowel pins if you did nothing.
3. How accurately can the average person actually do the alignment? And given the inaccuracies of doing the alignment, is the end result TRULY better than just leaving things be?
4. Although alignment issues may have been a problem in the past, are they REALLY an issue with the more accurate manufacturing today?
5. Given that GM uses a standard dowel pin and is out to save money, you can bet your bottom dollar they DON’T do a bellhousing alignment on their cars. Yet they generally run fine for hundreds of thousands of miles with no resulting issues.
What do you think? Am I missing something here?
Both are well within the acceptable range and will work out just fine. As for the QT SFI units, I have heard those usually need to be indexed and off set dowels are required to correct the runout.
I have the instructions included with the Bowler plate and they say that your final numbers should be within .010" total indicator reading. If you're planning on high performance shifting at 7500+rpm, then the total indicator reading should be within .005"
Mine required .007 offset dowels from RobbMC and I was able to get my Tremec bellhousing to .006" and called it a day.
