Clutch problem
Old Jan 9, 2022 | 05:41 PM
Catfishguy's Avatar
Default Clutch problem
I recently bought a 1998 ls1 Camaro 6 speed off my dads friend clean old car my dads friend buys and sells like my father and I ended up with this Camaro pretty cheap a clutch was just put in the car and we are thinking the master cylinder is bad
the clutch pedal when pressed goes flat to the floorboard and doesn’t return on its own we are thinking it’s a bad master cylinder but I’m not sure because I haven’t heard about this causing the car to not start
it won’t crank with the pedal pushed down does anyone have any experience with this?
Old Jan 9, 2022 | 10:40 PM
wannafbody's Avatar
I'd start by replacing the clutch master and then if that doesn't solve the issue, pull the transmission and replace the slave. The Tick Clutch Master is pretty popular.
Old Jan 10, 2022 | 09:30 AM
wssix99's Avatar
Save the manuals!
You have two separate problems here... (Clutch feel and starting the car.) I would start by removing the lower dash panel, laying on the ground and then looking underneath the dash to see what is going on. First check to make sure the pedal is right, actually connected to the master linkage, etc.
The pedal is pretty standard. You can find pictures of the mechanism (as it should be) online. There is a switch that senses when the pedal is pushed in, which will limit your ability to start the car. (Along with other sensors on the car. You should be able to download the Owners Manual from GM for free to see the full list of things that need to be set to start the car.) The stock car also came with a clutch pedal return spring, which is known for breaking. That may be gone or haning on by a thread. The stock spring has a barrel, a center bar and then two arms. The center bar and two arms engage the pedal mechanism. Commonly the arms break off. If broken you can toss the spring. (The new ones will just break again soon.) The nice thing with the aftermarket Master Cylinders, like the Tick unit, is that they require removing that spring.
