T56 won’t shift into 1st, 3rd, or reverse
Old Mar 29, 2022 | 09:15 AM
02TAsaxon's Avatar
Default T56 won’t shift into 1st, 3rd, or reverse
I was out driving recently and everything was going fine. I slowed down to pull into a gas station, I guess i turned pretty sharply but I don’t think that had to do with what happened next. As I pulled into the gas station I tried to put my car in 1st and it popped out. I have 4.10s so using second wasn't a problem. I decided to take the car home and found that 1st, 3rd, and reverse had all decided to stop working, 5th feels a little janky as well. I recently put an ls7 clutch in, but i don’t think that has to do with my problem. I’ve been told it could be an issue with the way i put the shifter assembly back on, or could have to do with the hydraulic system. Other than that I believe i’m in deep with this one, any ideas would be appreciated.
Old Mar 29, 2022 | 10:09 PM
AMP-D's Avatar
Sounds like a shifter stop came loose on the shifter base itself.
