T56 bleed problems
Old Apr 16, 2022 | 08:11 PM
77c10LS3's Avatar
Default T56 bleed problems
Hello,
I'm trying to bleed my T56 for the first time because of an inconsistent pedal. When I try to crack the bleed nipple it turns the whole tube and drains from the connection inside and the nipple. .is there anyway without dropping the whole unit to add an extension on or something that would solve this problem? I'm guessing if there is it would be a real mess to install but I'd really like to be able to get a vacuum on the bleeder but can't because air gets in from the joint. Thanks for any help and ideas.
