Room to work
Old Jun 7, 2022 | 09:04 AM
Barn Find CETA's Avatar
Default Room to work
Hey all. I doing a T56 swap on my 2002 trans am and I’m wondering If there is enough room to do the wiring once the t56 is in?? Will I be able to reach all the plugs and rout the wires nicely?? ( clearance between trans and tunnel for my hands) Im doing majorly of it my self. The shop will just put in the tranny, pilot bearing, rear main seal then car comes back for me to finish everything up Thanx.
Old Jun 8, 2022 | 10:43 AM
Darth_V8r's Avatar
Moderator
If you can get the car high enough, yes. The only thing difficult to reach with the T56 in the car is the top two bolts on the trans to bellhousing surface. I use 2-Ft socket extensions to reach them.
Old Jun 8, 2022 | 01:41 PM
Ok, I was just asking about reaching all the plugs to do the wiring on it once it’s in. I have a friend with a hoist that will help re and re the actual transmission. I’m doing the wiring later myself. So was wondering how prepare I need to be to do some
of it before the trans is in.
