Lt1 t56 to ls1
Old Oct 28, 2022 | 01:06 PM
Jack280zx's Avatar
Default Lt1 t56 to ls1
I have a lt1 style t56 out of a 96 Camaro z28 i was looking at the kit made by the gear box to swap to ls style but does anyone know if it would bolt up to a l33 bolt pattern in the same but im no sure about everything else
Old Oct 28, 2022 | 06:11 PM
It will bolt up to the L33, no problem. You will omit the bellhousing bolt at 1 o’clock because LS blocks don’t have that hole tapped. It’s too close to cylinder wall/water jacket to drill and tap. There are 2 added fasteners at bottom of oil pan (oil pan on LS platform is structural) that more than make up for the omitted bolt up top. LS shares same bellhousing bolt pattern as previous SBC/BBC engines.
Old Oct 29, 2022 | 04:07 PM
Jack280zx's Avatar
Thank you
