Tailhousing swap question
Old Apr 13, 2023 | 04:52 PM
george01transam's Avatar
Default Tailhousing swap question
OK, I recently purchased a t56 from a board member that needed a new tail-housing. I ordered the one from AMP that comes with the seal, magnetic drain plug and bushing. I had a machine shop transfer the old bearings and reverse idler gear. But now I cannot get the tail-housing to fit back onto the T56. Is there a special trick to getting it back on? or do i have to have it in a certain gear? Seems like the reverse gear wont mesh but I'm not entirely sure. Thanks in advance
-George
Old Apr 14, 2023 | 08:19 AM
AMP-D's Avatar
Take a small screwdriver or punch and push up slightly on the reverse shift rail.
Old Apr 14, 2023 | 06:32 PM
Yep that worked. Thank you so much
-George
Old Apr 15, 2023 | 09:32 AM
AMP-D's Avatar
Glad to hear it was a simple issue.
