Clutch Peddle Level???
Old Jul 24, 2023 | 05:07 PM
rll2's Avatar
Default Clutch Peddle Level???
I've never owned a newer car with a hydraulic clutch
All the manual transmission cars I've had in the past had the mechanical clutch linkage
Anyways, My clutch engages and disengages at the top of the peddle
Back in the day, that meant the clutch was about gone
Is that the same with the hydraulic setup
The clutch seems to work fine, doesn't slip or anything bad
Thanks,
Rob
Old Jul 24, 2023 | 05:39 PM
wannafbody's Avatar
It depends on the clutch master, clutch and if any spacers were used. If it works, I wouldn't worry about it.
