aluminum Flywheel?
Old Jul 25, 2004 | 07:56 PM
Bill's 02 Z-28 SS's Avatar
Default aluminum Flywheel?
Hi Folks
Now it is time to change the clutch and flywheel. My question is - replace the flywheel with aluminum one or keep the steel flywheel? The car is a garage queen so it is not my daily ride. Any help would greatly appreciated.
Thanks
Bill
Old Jul 25, 2004 | 09:37 PM
jrp's Avatar
jrp
SN95 Director
do a search for the pro's and con's. i went with the alumimum flywheel myself for the weight reduction and its suited for my application of autocross/roadracing.
Old Jul 26, 2004 | 06:27 AM
awesomeame's Avatar
i've heard for drag it's better to keep the steel, 'cause it's a bit heavier & hold the inertia better for a good launch...but i've only heard that
--matt
Old Jul 26, 2004 | 07:45 AM
Stick only's Avatar
Steel for street/drag, aluminum if you are autocrossing or road racing where you want to use the low inertia to 'engine brake'.
Old Jul 26, 2004 | 07:51 AM
Project GatTagO's Avatar
Let not forget that in addition to "engine braking" a lighter rotating assembly will result in much improved acceleration when you are exiting out of the corner.
Andrew
Old Jul 26, 2004 | 01:40 PM
2001CamaroGuy's Avatar
what he said.....
it worked wonders for me but I am desperately trying to KILL low end torque to make up for traction limitations and gain mid/high RPM power
